Max HP a 496 Gen I Cool Fuel system can support >
Old 05-08-2008 | 08:46 AM
Rage's Avatar
Default Max HP a 496 Gen I Cool Fuel system can support
What is the maximum HP that a 496 Gen I Cool Fuel system can support?
Rage is offline
Old 05-09-2008 | 07:59 AM
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
I dont know that there is a text book answer on this, but I would estimate it at about 525-550 non supercharged Hp.. For example if you reused it with a raylar kit & exhaust kit you would be ok. However you may benefit from a ecm remap & using an adjustable fuel psi regulator..
Jamie / Lakeside Restorations
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
Old 05-09-2008 | 09:38 AM
Rage's Avatar
Thanks Jamie.
I am more in the NA 600hp range. I do have an adjustable fuel pressure regulator. I will eventually have the ECU remaped but I need to breakin the engine refresh at a safe A/F by fuel pressure adjustment only and want to know what my 2004 Cool Fuel system is capable of. Besides the refresh there are several new increased HP engine mods as well. I already had to crank up fuel pressure to 64 psi just during the initial 15 min run at idle. Not sure what the other rpm ranges may require so looking for what the system can handle.
Rage is offline
Old 05-09-2008 | 10:40 AM
No problem.. You may want to also entertain a aeromotive pump set up along with upgrading the injectors for that kind of power.
Old 05-09-2008 | 02:08 PM
Rage's Avatar
I have already spent enough this winter so I would rather not unless it is necessary. I quess that is why I am asking what the stock system can handle.
Rage is offline
4mulafastech
23
11-07-2016 10:10 PM
Rage
0
05-06-2008 11:00 AM
xouterlimitsx
3
05-25-2007 04:38 PM
Rage
13
01-14-2006 05:53 AM
mjb
6
05-11-2005 09:33 AM
