When to change the sea pump housing? >
Old 05-09-2008 | 05:03 PM
Default When to change the sea pump housing?
Is this bad or is time for a new housing?
Attached Thumbnails When to change the sea pump housing?-pump-001.jpg   When to change the sea pump housing?-pump-002.jpg   When to change the sea pump housing?-pump-003.jpg
MacGyver is offline
Old 05-09-2008 | 05:46 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
I replace mine every other yr. They always have the melted appearance at the end as yours does. I think that is normal wear. The 2 grooves are more than what I see normally.
You got it apart, put in a new kit.
I doubt it's needed, but I always sand the mold parting lines smooth on the inside too. Figure might as well eleminate those sharp edges to keep them from cutting the new impellor. Only takes a minute to do.
US1 Fountain is offline
Old 05-09-2008 | 05:54 PM
There is a plug with a separate number that fills the void and the end of the shaft. Don't know why merc doesn't put it in the kit but most people omit it. That housing looks like you have sand there. Any way like US1 says change the whole kit housing and all. There is much at stake. if you do a lot of boating 100 plus hours and have sand change impeller every season.
MOBILEMERCMAN is offline
Old 05-09-2008 | 06:07 PM
obnoxus's Avatar
Charter Member #1171
There is a rule of thumb,,,, throw it in the lake and see if it floats,,, if it does,,,,you can reuse it !!!
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 05-09-2008 | 06:08 PM
Yeah, I sucked up a crapload of sand last summer when I came off plane at a local hotspot. The water level was really low...my bad. The sea strainer caught a bunch of the sand, but I guess quite a bit got through. Now I'm wondering how much got into the engine and has settled in?
MacGyver is offline
offshoredrillin's Avatar
exactly, if you cant find that rubber plug and have some flat rubber stock around an 18mm socket is the right size to make it. but you knew that didnt ya jim?
offshoredrillin is offline
Old 05-09-2008 | 07:36 PM
t500hps's Avatar
21 and 42 footers
I change the impeller AND the housing EVERY spring just in case...
t500hps is offline
Old 05-10-2008 | 08:08 AM
BillR's Avatar
OSO Moderator
Never heard of that or seen one. More info please.
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 05-10-2008 | 08:44 AM
it's a round piece of rubber that covers the shaft and goes against the back of the housing. Helps with pressure and stops any debris if sucked up from entering shaft. Also acts as a spacer.
Old 05-10-2008 | 08:49 AM
BillR, The part # is 19-59504. It is shown in the break down on 420's and 425's. It was used on the 2 piece sea pumps. I doesn't show up on the one piece cards. I can only guess since the impellers got re-engineered to fail by third season { I say in jest } they don't get included in the one piece housing pix. Any way they will help the housing to wear evenly on the end.
BillR
11
07-29-2022 06:31 AM
alecsammy
0
09-21-2008 09:47 AM
MacGyver
05-15-2008 01:33 PM
HP500Hammer
15
01-30-2008 06:03 PM
BeakBoater35
4
08-29-2005 08:33 AM
