Bravo Drive / Speedo question/Outlaw
I have a Bravo One X drive on my 2004 25 Outlaw. Today I was changing the yellow adapter that connects to the tube that connects to the speedometer and noticed that I have a cut in the tube a few inches above the adapter. I'm guessing my speedometer is not going to work? Any other negative effects?
How do you fix this? Tape it? Do I need to replace the entire tube from the drive to the speedometer? Does the tube have extra slack from the factory, thinking maybe I could just pull it out and cut it above the area that is cut, and reconnect to the adapter?
Any suggestions, answers ideas?
You can try to shorten it and see if it works, otherwise cut back the bad section and go to a parts store and get a small length of hose and an inline splicer and hook em altogether and go.
1BIGJIM
Drives and Lower Units
3
06-10-2008 12:46 PM
