Prop what pitch >
Prop what pitch
Prop what pitch
Old 05-11-2008 | 11:47 AM
Default Prop what pitch
I got a 24ft Baja with a 454 mpi with Gil exhaust. It seems to go pretty good now with a Bravo1 24p 4blade and revs 49-5000rpm. It just barely hits about 65mph on the speedo. Is there more mph there with possibly another prop pitch or design.
prostockcat is offline
Old 05-11-2008 | 12:47 PM
No it sounds like your right there. My buddy has the same boat. thats about as fast as they go stock. I would leave it alone.
I DIG IT !! is offline
Old 05-11-2008 | 02:09 PM
Isn't the rev. limiter @ about 5300 on the 454? If it is, you could get your current prop labbed, pick up 200rpms, and top end as well. Carder
Carder is offline
Old 05-11-2008 | 08:07 PM
you have to go to a 25 mirage 3 blade !4 blades lift the back of the boat baja likes 3 blaDES THEY LIFT THE BOW I TRY ALOT OF PROP BEEN THERE .TRY 25 MINE TRUN 4800 I HAD CUP REMOVE IT RAN 5000 AT68MPH
bajabob is offline
Old 05-11-2008 | 08:45 PM
Is it a 24 outlaw or a 240???
I would guess a 240 from your numbers. Almost all 24 Outlaws with stock 365-415hp run a 23 Mirage plus for the fastest top end. Plaining time sucks.
A 240 is lighter and has less deadrise, so a 25 Mirage plus would be the prop for the best top speed. Cruise speed and plaining time will suffer though.
Griff is offline
rch662
Superboat
11
09-02-2006 10:05 PM
white scarab
Prop Talk
4
06-13-2006 06:26 PM
white scarab
Scarab
0
06-12-2006 05:19 PM
Smitty
Prop Talk
1
06-06-2005 03:13 PM
bvs629
23
03-19-2003 11:07 AM
