power steering pump - broken stud >
Old 05-19-2008 | 09:30 PM
Default power steering pump - broken stud
'89 7.4L
I have a broken stud on my power steering pump. It's the one that goes into the slotted bracket and allows you to rotate the pump/reservoir and tension the belt. (hope that makes sense)
The stud appears to have a hex shaped flange that protrudes about an 1/8 inch. Can I put a wrench on this and remove it and replace it? Will I end up with power steering fluid all over the place if I do remove it?
Or is this a situation best solved by replacing the whole pump/reservoir? Can a standard automotive pump be used or is this an ignition protected item? (doesn't seem like it)
Thanks,
Kevin
edge_kw is offline
Old 05-19-2008 | 09:37 PM
You can take it out without losing fluid. It is a very common problem.
speedreeder is offline
Old 05-19-2008 | 10:11 PM
Mr Gadgets's Avatar
Charter Member #601
Kevin,
Had the same thing happen to me twice. I was on a weekend out and found it broken. I went to an auto parts store and picked up an exhaust stud, added two washers and it has been in there for about 5yrs. You can pull it without a problem, blind hole..
Hope this helps.
Dick
Mr Gadgets is offline
Old 05-20-2008 | 04:22 AM
Went through the same thing on one of my Merc 800SC's with a blue pump. I stopped by my friends car repair shop,told him what happened and left 5 minutes later with a stud he removed from an old pump. Problem solved!
Lmarth is offline
Old 05-20-2008 | 06:36 AM
Thanks for the replies. I'll pick one up tonight and give it a shot.
edge_kw is offline
bobkatz
5
07-05-2007 10:51 AM
Dono
4
08-17-2005 04:37 PM
florida gator
5
05-21-2003 09:08 PM
jdelo
7
02-23-2003 11:14 AM
BAD-HABIT
7
06-23-2002 11:02 PM
