Trailer bearing questions
I have been debating on going to the oil bath system and was wondering what the pros and cons are.
I trailer about 40miles each way to get to the lake or the bay and most of my boating is n salt water. The reason i have been thinking about this is i am tired of the grease slinging all over the wheels and having to put grease in them on the way to the launch and back home. I checked everything and the bearings are fine and seals still intact.
Registered User
I've heard that oil bath hubs don't like to be dunked. Not sure why- I know they run nice and cool and the saels are substantial. The oil isn't really water resistand like a good silicone wheel bearing grease is.
You might call Myco and ask- their big custom trailers often have them.
Considering the salt, I'd say stay away from oil bath unless everything is galvanized. The oil bath hubs I've seen weren't on galv hubs.
Why is grease slinging all over the place? You need new rubber plugs, bearing buddies, or perhaps a set of these:
http://www.airtighthubs.com/products-SS.php
I sell bearings for a living and OIL is far superior to grease any day and I would switch over on my trailer if they made a kit to fit but I have not ever found one for the heavy axles on the Myco.
As mentioned you should consider the construction of the components if you are dunking into salt water for sure.
That said I have towed trailer 100,000 miles with grease packed wheels and NEVER had a failure. With just simple routine maintenance and grease lubrication will keep you trucking for many a mile.
Registered User
Charter Member#1545
Sam
Yep. And why does everyone feel the need to grease their bearings everytime they pull the trailer? Is that grease magically dissappearing?
