Trailer bearing questions
Old 05-21-2008 | 10:01 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Originally Posted by BY U BOY
I chedcked all the bearings and repacked at the start of season. also replaced all the bearing buddies and gave all of them 2 pumps of grease. Still slings grease.
Did you replace the rear seals with the rubber seals that have the circumference spring built into them? I have found that these are the best rear bearing seals, but they do give up over time.
Sydwayz is offline
Old 05-21-2008 | 10:34 PM
Registered User
Bearing Buddy makes a "Spindle Seal" which is a seal with an additional o-ring and a shield. You can also convert to EZ Lube axles which eliminates the pressurized hub issue and keeps your bearings full of new, fresh grease.
Chris Sunkin is offline
Old 05-21-2008 | 10:53 PM
BY U BOY's Avatar
Thanks guys! I think i will pull the trailer over to McClain and have them check everything.
BY U BOY is offline
SKRAMER
10
05-23-2008 06:16 AM
Indy
27
04-10-2008 07:37 AM
cbeastwood
6
05-29-2007 09:33 PM
FlyFast
34
05-25-2004 11:12 PM
familyman
08-26-2003 08:04 AM
