Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Re: removal of mineral or water depostis . >
Old 05-27-2008 | 02:25 PM
Default Re: removal of mineral or water depostis .
I have a new Fountain , and from being in the water at Lake Texoma over the weekend the prop,transom and all the braided lines have a coating of calcium or something covering all these pieces. My question is does anybody know what to use to disolve these deposits? I can take my finger nail and scratch it off of the propeller. Will any thing like CL
R help?
Thanks,
Chris
elise909 is offline
Old 05-27-2008 | 08:20 PM
Yes CLR, lime away, are good for real hard water spots. Try vinegar first it is not as harsh,but most of the time it will work fine. You can dilute the vinegar with water try it diluted if it don't work use it straight. If you use CLR or LIME AWAY try a little spot out of the way first to see if your going to have a problem with it etching your paint or Aluminum. All three of these will remove all of your wax so you will have to wax the parts that are affected.
B one is offline
Old 05-27-2008 | 09:52 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
I've used Sno Bol toilet bowl cleaner for yrs to rid the calcium build up. Just sqirt it on and it'll dissolve the build up instantly. Rinse well afterwards. Takes that nasty white chaulk off your drive too if you have any.
US1 Fountain is offline
randy carlson
Drives and Lower Units
4
10-24-2007 02:36 PM
littledcsrodshop
2
07-09-2007 09:08 PM
AGGRAVATION28
3
01-22-2007 01:49 PM
mlitefan
6
06-29-2003 09:05 AM
