Boat help
Griff, I understand that if they are spinning in the same direction this would cause the boat to act this way. If I have a left and right prop on and they spun in the same direction would this not rob me of a lot of speed?
Registered User
How about posting what boat and driveline as well as anything else you can describe your setup by? If you had "left and right" props on same-rotating drives, you'd be going in very small circles. Leaning would be the least of it.
Sounds like you might have a hook in the hull, or something in the gelcoat/paint to slow the strbd side. Also possible that the RPM's are out of sink.
Stupid question may be , but "props are same pitch"??
. I think what he is trying to tell you is to make sure your props turn in opposite directions.
