600 SCI Upgrade to 700  HP now available >
Old 05-29-2008 | 12:43 AM
Default 600 SCI Upgrade to 700 HP now available
back from the dyno in Italy we received our engines back with 110 more HP per engine
The Kit is devoloped by an Italien Company on the Lamborghini Dyno in Modena Italy
Itr contains a reprogrammed PCM 555 ECU (with all guardian and smartcraft functions), a camshaft and a pully - thats all you have to change
We will distribute the kit in Europe -
Our first Dealer in the USA will be Raylar
www.raylarengine.com
there are two different Programms available - one with full torque and one with a reduced torque in Midrange RPM for stock Bravo XR applications
stock torque of a 600 SCI is 600 lbf-ft (83 kilopond meter or 830 NM )
maximum torque now is 752 lbf-ft (104 kilopond meter or 1040 NM)
File Type: pdf
pokerrunboats is offline
Old 05-29-2008 | 06:03 AM
Canada Jeff's Avatar
Thats more like it. Good on you. Congrats!
Canada Jeff is offline
Old 05-29-2008 | 07:19 AM
Registered User
Will this program also be available for the Raylar 496 kit?
Make it a Double is offline
Old 05-29-2008 | 07:37 AM
The Programm file will be put into the PCM of the 600 - it will not work on a 496 - only on a 600 SCI
For every programm modification , once an engine needs to run on the dyno - After That we can copy the file into any engine of the same specs
If you need a custom programm for your 496 Raylar Kit call Ray @ raylar
We offer an ECM Modification, not a software to do it yourself !
Old 05-29-2008 | 07:22 PM
Do you have an email address, I have some questions?
800XCR is offline
Old 05-29-2008 | 08:40 PM
Whipple Charged's Avatar
If you go to the 700sci boost/pulley speed, yet, use the 600sci intercooler core, then you'll exceed the maximum manifold temperature. Might be better to keep it at 75hp, stock camshaft, stock pulley. I'll soon be releasing our bigger SC (4.0Liter) for the 600/662/700 packages, will keep the IAT's down significantly.
Thanks,
Dustin
Whipple Charged is offline
Old 05-29-2008 | 09:24 PM
Thanks,
Dustin
Your phone will be ringing soon Dustin.
MahopacMarine is offline
Old 05-29-2008 | 10:38 PM
[email protected]
For Europe we offer a 42 Month warranty on engine and drive when installed from us ! This is as unique as the reprograming of the PCM 555
If Intake temps were too high the engine would loose a lot of power and go into guardian - it does not !
Maybe thats an issue in areas with water and air temps in the 80 `s
The larger intercooler of the 700 SCI is an option, but it will not fit under everybodys hatch -
Maybe someonen has a more efficient intercooler with the same Dimensions as the stock unit - that would be a great addition
Old 05-29-2008 | 10:44 PM
Thanks,
Dustin
will this kit run on modified or stock PCM 555 or on a MEFI 4 like your Kit for the Mercury Racing 525
Old 05-30-2008 | 05:37 AM
[email protected]
JESUS !!! on a bravo drive ???? Your going to go broke.....
