velocity 290 sc with 600 sci motor xr drive >
Old 06-03-2008 | 03:11 PM
Thumbs down velocity 290 sc with 600 sci motor xr drive
need ideas on props to try boat weighs 4800 lbs with 600 sci motor xr drive 2008 velocity 290 sc
ran 15x28 5 blade stock turbo precision 5100 rpm 78 mph on gps
ran hydromotive 15x27 5 blade lab 1 5000 rpm 76 on gps
ran bravo 15x29 4 blade stock 5000 rpm 76 gps
all test were in 1 ft chop 1/2 tank gas 2 people
wellcrafted is offline
Old 06-07-2008 | 12:37 PM
hoozeyurdaddy's Avatar
what are your goals, top speed, mid range, holeshot, what max rpm are you looking for, it looks like you have aready tried some good props, was the hydro a P5X or a P5?
Larry
hoozeyurdaddy is offline
Old 06-08-2008 | 06:19 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Customizing any of these props can get you closer to the WOT rpm of 5400. You will gain smoothness acceleration and some top speed.
You do need to determine your ultimate goals.
[email protected]
bbladesprops is offline
RICKY PEREZ
43
09-11-2023 06:30 PM
wellcrafted
Velocity
15
07-11-2008 10:08 AM
TeamSaris
Baja
65
01-10-2008 11:39 PM
