leaking horn >
leaking horn
leaking horn
Old 06-03-2008 | 08:04 PM
Default leaking horn
got a 05 33 outlaw, when it rains it leaks threw the horns in the bow. anyone have this problem. thanks
battlefieldtow is offline
Old 06-03-2008 | 08:44 PM
Dock Holiday's Avatar
Charter Member #34
I did on the 36 and always had horn problem so I solved it.
I very neatly taped over the horn with blue electric tape and sealed it back with silicone around the edge then put the bezel back on and you just see the blue tape through the slots. NO MORE WATER.
Then I mounted a $19.00 plastic dual trumpet air horn from Advance Auto inside the air intake for the engine and it works like a charm!
My horn was already bad and it was the second time I replaced it so I made a change. If your horn is still good you may just need to reseal it around the edges. It needs some silicone because the gasket alone is not enough.
Good luck.
Dock Holiday is offline
Old 06-04-2008 | 09:54 AM
thanks.
Old 02-24-2010 | 03:09 PM
Wow, thanks guys. I've been wondering where my mysterious water was coming from. I thought it was the nav. light. I'm going to check the horn. Glad I did a search
Sacandaga is offline
Old 02-24-2010 | 03:34 PM
Smitty's Avatar
Also check the cups below the bow cleats if you have the popup cleats. They crack and leak water too.
Smitty is offline
Old 02-24-2010 | 04:46 PM
Had the same problem on my 1999 36 Outlaw. I started by caulking around the base of the horns on the exterior. I was getting water in the area in front of the bulkhead and it was to the point it was seeping into the v berth. I removed the bulkhead to drfain all the water. While it was removed I caulked the horns from the inside. There must have been a horn caulk shortage the day mine needed it as there was little to none on the inside. Now on the other hand on the other thru deck items in the area there was an over abundance.
That is the approach I would take if I was you. Get to know your boat better in the process!
Mark
GETTINBYE is offline
Old 02-24-2010 | 06:58 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Don't know if your boat is cored there or not, but if it is, make sure the coring has been sealed with resin. Otherwise the coring will soak it up like a sponge. Water between the inner and outer skins ain't good. Just going on the fact that all the holes drilled thru any glass on my Baja were not sealed and the coring was wet.
US1 Fountain is offline
Old 02-24-2010 | 09:21 PM
Good luck.
I don't know why all boat horns aren't installed in the engine compartment. I can't stand having them on the bow. All it does is clutters up the bow and gives you one more thing to trip over, and one more place to potentially leak.
wjb21ndtown is offline
Old 02-25-2010 | 08:08 AM
Thanks for the advice. One reason I've been using a full mooring cover since 04, stop the leaks. Just one more small bug to iron out. By year 10 of ownership, I should have this thing perfect
dencam7
General Racing Discussion
0
07-30-2007 10:48 AM
carney
Baja
0
06-07-2007 09:03 PM
John Worthing
Fountain
7
04-25-2007 11:34 PM
Hydrocruiser
08-22-2004 07:26 PM
thomas1369
4
03-31-2004 11:13 AM
