door adjar light
Old 06-08-2008 | 11:22 AM
tuffenuff355's Avatar
Default door adjar light
i own a 2003 ford expedition door adjar light stays on ,witch also controls interior lights and side lights on side veiws witch also controls the anti theft alarm that wont ingage because of this problem . anybody experience this problem if so how can i fix it myself? I checked out all the doors and cant find the sensor
tuffenuff355 is offline
Old 06-08-2008 | 02:47 PM
The sensors are on the latch mechanisms. They require door panel removal to gain axcess. Stuck door sensors are a very common problem.
JMS322 is offline
Old 06-08-2008 | 05:03 PM
spazboz's Avatar
Very common problem. A temporary solution that sometimes works until you can get your replacement part is to "flush" them out thourougly with WD-40, to clear any debris that may be on the track of the sensor.
spazboz is offline
Old 06-08-2008 | 06:42 PM
The WD-40 flush worked for me. That was 50K miles ago.
fossil fuel is offline
Old 06-08-2008 | 07:12 PM
Audiofn's Avatar
Charter Member #232
Yup WD-40 the mechanism every 20,000 or so and you are good to go.
Jon
Put your best foot forward!
Audiofn is offline
Old 06-09-2008 | 07:24 AM
Airpacker's Avatar
Rusty Ford door latches? Say it ain't so
I have replaced over 100 of those little latch switches for exactly that reason. 9 times out of 10 its the driver's door.
Airpacker is offline
Old 06-09-2008 | 07:44 AM
berns29scarab's Avatar
i've also replaced a ton of GEM modules...more so on the windstars.
berns29scarab is offline
Old 06-09-2008 | 03:43 PM
guys thank you so much for the advise , Its been driving me crazy, Ill let you know how i make out. THANK YOU AGAIN!
Old 06-18-2008 | 09:31 AM
well how'd you make out
Old 06-23-2008 | 03:48 PM
sorry for the late reply wd-40 worked great!!!! problem solved, thanks again!
Strip Poker 388
18
07-20-2007 08:00 AM
bernm3
Outerlimits
1
09-21-2006 07:53 AM
bernm3
1
09-20-2006 07:21 PM
1HYPER1
03-19-2003 09:46 PM
