Valve Cover Breather Recommendations >
Old 06-10-2008 | 09:23 AM
seafordguy's Avatar
Default Valve Cover Breather Recommendations
Anyone have any recommendations on Valve Cover Breathers. I have the cheap Mr. Gasket ones and they tend to leak which tends to run down the valve cover and end up in the Bilge. I want some Filtered ones - need them to go up and angle properly so they sit straight up. Any Recommendations??
I believe I have the Gen IV valve covers, the ribbed ones with the push in breather hole that points straight out at a 45 degree angle.
Don't want a puke tank at this point.
seafordguy is offline
Old 06-10-2008 | 09:36 AM
pkspx's Avatar
I don't think you would want a catch can, are you NA or boost?
pkspx is offline
Old 06-10-2008 | 09:38 AM
seafordguy's Avatar
Conservative Blowers....
Old 06-10-2008 | 09:45 AM
Even with the expensive ones , igot the same thing going on.
My enginebuilder told me thats normal.
DareDevil is offline
Old 06-10-2008 | 10:49 AM
BY U BOY's Avatar
Unless you put in a puke tank you can expect to keep cleaning it up.
BY U BOY is offline
Old 06-10-2008 | 03:33 PM
Strip Poker 388's Avatar
Rob
To me the puke tank made a bunch of diff!! I don't even get that crank case oil smell anymore when ya run it hard.Every filter/breather iv seen and had leaked on the valve cover.This tank is 79. at Peterson.It has a baffle plate and foam in it.
Also all the small breather/puke tank with the chrome filter on top Ive seen leak and blow oil out.
I have some more picks
Attached Thumbnails Valve Cover Breather Recommendations-4082653.jpg   Valve Cover Breather Recommendations-tickfaw%25205-5-2007%2520074%2520%2528large%2529.jpg
Strip Poker 388 is offline
Old 06-10-2008 | 05:28 PM
What he said
Old 06-10-2008 | 05:41 PM
Does peterson have a web page ?
But also i heard if you install a overflow tank ,that the press. in the crankcase builds up more and you can breake the engine faster ?!
Old 06-10-2008 | 05:52 PM
Hey Devil this should work 4 ya http://www.petersonfluidsys.com/tanks.html
you can breake the engine faster ?!: wher'd ya hear this chit ????
Old 06-10-2008 | 06:06 PM
Rob
Does Peterson have a web page ?
There breather tanks.
I had this one on the Scarab at 12psi, you could smell the oil and see the steam come out of the K&N breather on it.http://www.petersonfluidsys.com/Photos/brecansm.jpg The big lines (#12) lets the oil separate from the blowby also the take will separate it. I had a 3/8 line going to a K&N this is the way Whipple did it, it would blow oil every were. Once I put the tank on it no oil vapor coming out of it and I don't have that burnt oil smell coming from it anymoreyou could do the tank a nd get them to put hose barbs and run rubber hose or something like it to make it cheaper,the #12 stuff like I did is expensive. Like I said the tank is only 79 and they will make it in ant configuration of fittings,hope this helps
