lean at high rpm?? >
lean at high rpm??
lean at high rpm??
Old 06-10-2008 | 01:35 PM
Default lean at high rpm??
hi,
i have a mercruiser 502mpi, with a procharger m1sc.
i upgraded my fuel pump to XS (for 1000hp), and installed a procharger fuel regulator, and am still running lean at high rpm!
i tried to increase fuel pressure up to 5bar, but still ruuning lean at high rpm!!! but at low rpm its rich!
am running 5psi boost!
so can anyone help me plz??
10x,
cheers!!
jijo is offline
Old 06-10-2008 | 01:53 PM
jayhawk261's Avatar
Sounds like you need to have your computer re-programmed to change the fuel map. Upping the pressure can help tweak it, but if the fuel map is incorrect, you can't fix it with pressure only.
The best solution is to put the engine on a dyno and have it tuned so that the A/F ratio is correct and the egt is good as well.
the other alternative to do it right in the boat would be to add an O2 sensor fitting and tune the A/F ratio in the boat. You won't have a HP number then, but you can get the fuel map right.
I'm sure the procharger came with a program, but most times they are not right and need to be tuned on the engine. Sucks to have to do that, but that's the price we really have to pay for going fast!
jayhawk261 is offline
Old 06-10-2008 | 02:29 PM
Which computer do you have? I have a mefi 1 you could try.
kennyo is offline
Old 06-11-2008 | 06:28 AM
Canada Jeff's Avatar
Perfect recomendation !!!!
Canada Jeff is offline
Old 06-11-2008 | 06:57 AM
Michigan Mad Man
Originally Posted by jijo
hi,
10x,
cheers!!
You can call me at the shop 8103242720 Tyler PS. give me the part # off the back of the ecu.
TylerCrockett is offline
Chicago290
6
05-22-2006 03:16 PM
nadledvinka
8
06-29-2005 05:31 PM
Sates
8
04-16-2005 02:45 PM
MAX VELOCITY
6
07-29-2003 10:13 PM
kathycool
10
07-01-2003 09:13 PM
