Help if you can >
Help if you can
Help if you can
Old 06-10-2008 | 08:52 PM
fountainfevr's Avatar
Default Help if you can
Friend has 2000 502 mpi. He had a blown head gasket and replaced it. Now it surges on idle, backfires and can only get 42-4500 RPM. (prolly not enogh info to work with but it is a start)
fountainfevr is offline
Old 06-10-2008 | 10:16 PM
It sounds like the rocker arms are to tight and/or valve is hanging open.
Griff is offline
Old 06-11-2008 | 07:28 AM
ck vacume, sounds like may have a leak, timing set correctly ?
ezstriper is offline
Old 06-11-2008 | 08:46 PM
we will check timing tomarrow. How do you bypass the computer to reset the timing?
Old 06-12-2008 | 03:43 PM
Airpacker's Avatar
check the 5 and 7 plug wires. might be crossed.
Airpacker is offline
Old 06-12-2008 | 04:02 PM
Take a can of throttle body cleaner or starting fluid spray small amounts around intake to see if you have a good seal. Don't spray too much just a little at a time. If you have a vacuum leak you will know it.
B one is offline
Old 06-12-2008 | 04:07 PM
obnoxus's Avatar
Charter Member #1171
If its stock,, there are not adjustable.
Sounds like he didnt bypass the ECU to time it.
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
