Go Back  Offshoreonly.com > Owners Forum > Powerquest
22 Raizor - Muffler Removal >
Old 06-12-2008 | 11:19 AM
Default 22 Raizor - Muffler Removal
I just bought a 22 Raizor. I am wondering how I go about removing the mufflers that are on it. I took a look at them the other day and there are no screws or bolts of any kind visible except for the on bolt inside the pipe. When I bought it the broker said the owner added them so I figured they would be easy to remove so I did not think to ask them how to do it.
Any help is greatly appreciated...
interOctave is offline
Old 06-12-2008 | 01:00 PM
Knot 4 Me's Avatar
Pics would be helpful. Are these a slip-on muffler? Not sure I've ever seen one that attaches with a single bolt located inside the muffler.
Knot 4 Me is offline
Old 06-12-2008 | 01:31 PM
I will try to get some pics of them soon.
Old 06-12-2008 | 01:49 PM
Any chance this Raizor was bought in Harrison Twp. at Lands End
moxxy13 is offline
Old 06-12-2008 | 01:58 PM
I had a 99 22 Raizor. It came from the factory with mufflers on a MPI 7.4L.
They looked like the ones in the "Transom.bmp" pic in post #8 of the "Couple questions for 38' Avenger owners" thread.
I have no knowledge of how to remove them. But it seams almost everywhere is cracking down on boat noise.
Good luck.
NEED4MEAD is offline
Old 06-12-2008 | 02:33 PM
Knot 4 Me's Avatar
Good luck.
Ah, if those are what he has then now the single bolt in the pipe makes sense. He wants to be able to gut the muffled factory tips. Not sure it can be done but even if it could it is a bad idea as then there would be nothing to prevent water reversion since it is an angled tip and you could not install a rubber flapper once you gutted it. I would remove the tips altogether and go with a straight-thru tip with a built-in stainless flapper if you want it to be louder. Corsa makes a nice set as do many others.
Old 06-12-2008 | 03:06 PM
moxxy...I did get it from Lands End.
Old 06-12-2008 | 03:11 PM
The pipes in the picture of the 38 Avenger transom resemble mine from that angle. So those are factory installed mufflers? Guess I will need to get new pipes then.
Old 06-12-2008 | 03:40 PM
I almost bought that boat.
moxxy13 is offline
Old 06-12-2008 | 05:41 PM
Runs beautifully. I think it needs a different prop though.
grads2112
3
01-03-2007 09:23 PM
BrandonG
08-06-2006 03:53 AM
Fast Forward
Powerquest
9
05-09-2006 01:25 PM
mcraymond3
7
02-23-2005 05:00 PM
Raypanic
4
04-10-2003 01:05 PM
