Tired motor ? >
Tired motor ?
Tired motor ?
Old 06-15-2008 | 12:29 PM
Default Tired motor ?
last year I had to tune turn the idle up because it would barely run at 650 rpms. Then it would not shift out of drive being that I had it to high, I turned it down. Now it has a harder time starting at such a low RPM. This motor is a 1986 in a older 23 Powerplay. I am thinking that the motor may be getting tired... or really just the cam ? it does not burn any oil and a few years back it had some oil pressure issues and I thougth it might be the gauge and got it back to the marina and it was the oil filter. That was 2002 ?
any ideas ?
Thanks,
Steve
powerqrudy is offline
Old 06-15-2008 | 12:39 PM
Rookie's Avatar
Engine? Carb? Setup would help.
Carb rebuild time? power valve?
Does it run good when off idle? have you lost performance (besides idle)
Rookie is offline
Old 06-15-2008 | 12:49 PM
Yes, carb rebuid a couple of years ago.
350- 260HP
New cap, rotor, wires and plugs in the last 2 years.
this thing use to crank 4800 now maybee 4200 RPM ?
Old 06-15-2008 | 01:40 PM
baja36ft's Avatar
do a comp test.... plugs should be done at 50 hrs.....
baja36ft is offline
Old 06-16-2008 | 01:49 PM
Knot 4 Me's Avatar
Do a leakdown test. Might be time for a valve job.
Knot 4 Me is offline
Old 06-16-2008 | 03:07 PM
ok, at what point do I just yank it and put in a new one ?
if the cam is shot and it needs a valve job ?
maybee the cam is ok??
keep them comming ...the advoise that is.
thanks,
Steve
Old 06-16-2008 | 04:31 PM
baja36ft's Avatar
i have a 454 just rebuilt i will sell you....
baja36ft is offline
Old 06-16-2008 | 07:31 PM
would it even swap right in with a Alpha ?
what year and model
330HP
365 HP
420HP
Old 06-16-2008 | 08:28 PM
baja36ft's Avatar
what year and model
330HP
365 HP
420HP
Anyone Looking For A 454 30 Over Gen 4 Rebuilt Ready To Go.
Have Exhaust (cmi)...new
454 460 ci
holley carb 830
rpm performer intake
steel crank
4 bolt
srp pistons
dimple rods
crane cam (134241) 534/553 lift 226/236
baja36ft is offline
Old 06-17-2008 | 08:10 AM
Sounds like it might have a vacum leak. That is usually the case with and idle problem like that. The carb might be wore out. Throttle shafts worn? causing a leak maybe. but look into that.
Budz Motorsports is offline
