Go Back  Offshoreonly.com > Owners Forum > Donzi
Running Temps on 26ZX with 454 mag >
Old 06-16-2008 | 09:12 PM
Default Running Temps on 26ZX with 454 mag
I am wondering what others are gettin for temps on there boats, I have replaced and flushed everthing including raw pump&housing, t stat 160 ? Cruising 175-178is and on throttle 180-181?? Is this good?? or is it to hot any ideas would help thanks .
mattd7 is offline
Old 06-16-2008 | 09:24 PM
Shanghied Again's Avatar
Registered User
That is a normal a 160 degree thermastat will run 20 over. 180 is normal for 454/496/502 any temp over 200 is bad.
Shanghied Again is offline
Old 06-16-2008 | 09:28 PM
Thanks should I go with a 140?? what do you recommend
Thanks again
Matt
mattd7 is offline
Old 06-17-2008 | 08:48 AM
Registered User
If you go to low on temp is not the best for an engine Mercury engines have an over heat alarm so if the engine goes above 210 the alarm will go off. Make sure you have plenty of water flow through the exhaust
WMF
8
11-24-2016 03:32 AM
cliff3466
1
03-09-2008 08:10 AM
LAKESIDE RESTORATIONS
Donzi
14
11-06-2007 11:18 AM
JB4Boyne
2
08-31-2007 09:19 PM
ITLLFLI
11
07-18-2005 10:12 AM
