Checking oil?
Old 06-17-2008 | 02:15 PM
Default Checking oil?
Witch is more correct level when checking the oil. In the water or on the trailer?
nova26 is offline
Old 06-17-2008 | 03:18 PM
Sea-Dated's Avatar
I would say on the water. The engines are positioned to be running in the water, not on the trailer. Of course I don't think there should be a difference between the two if you have the boat level on the trailer.
Sea-Dated is offline
Old 06-17-2008 | 03:48 PM
fund razor's Avatar
Tell the witch that either way will be fine.
fund razor is offline
Old 06-17-2008 | 06:08 PM
LOL!!
nova26 is offline
Old 06-17-2008 | 06:49 PM
Sydwayz's Avatar
Forum Regulator
In the water.
Pick up a mini-level commonly used for leveling RVs. (Wal-mart)
Next time you put your boat in the water, stick the level inside of a compartment on one of the side walls.
Then, when you put your boat on the trailer, you will be able to adjust your trailer's tongue stand to match when the boat is at is water level setting. You can also stick another level on your trailer at this point, and be able to set your trailer to the same setting without climbing in the boat.
Sydwayz is offline
Old 06-17-2008 | 08:14 PM
I don't have a owners manual not that it probably makes a big difference but does anyones boat say to check it a certain way? Just curious.
nova26 is offline
Old 06-17-2008 | 08:29 PM
bouyhunter's Avatar
You'll know she's a witch if she floats.
But, then again, ducks also float.
bouyhunter is offline
Shore Thing
8
09-14-2006 06:10 PM
resurrected
01-18-2006 10:04 AM
TRG Ange
10-22-2003 09:57 PM
Tigger
02-18-2002 08:56 AM
