Mirage Plus solid hub/ TRS question
Ive got a solid hub, (non flo Torque) Mirage plus that I plan on running on a TRS.
Do I need an external thrust washer for this? With the thrust washer it seems to sit pretty far back on the shaft and will not allow the splined washer to connect with the shaft splines. There looks to be a brass "washer" pressed into the back of the hub on the prop....is this some sort of a built in thrust washer?
W/ out the external thrust washer it seems to be too far foreward on the shaft although it doest rub the drive housing its pretty dammned close, the splined washer will grab plenty of the shaft splines this way.
What am I doing wrong here??
The part number for the thrust washer to use is.....
14359
14359
[email protected]
[email protected]
