Go Back  Offshoreonly.com > Owners Forum > Motion
how fast 30 with 225's >
Old 06-29-2008 | 10:43 AM
Default how fast 30 with 225's
just got my new to me 30 with 225's.only pulled 78 on gps.thought it would be alittle faster.am i missing something.this is my 1st boat with twin outboards.it was very calm on the lake.should it run faster with some chop?thought it would run 83-85
awsomethunder is offline
Old 06-30-2008 | 11:18 AM
Usually my Motion does not like smooth water. It tends to run a little slower than normal and proposes a little more. Mine ran the best in a 1 to 2 foot chop.
You might want to measure your X dimension and see where you are at. It the motors are too low in the water that will also slow you down.
Hope this helps
Don
Maritime_Eng is offline
Old 06-30-2008 | 12:28 PM
don should i be turning my props in or out.it seems alot of cats are turning out.where should my x dimension be?
Old 06-30-2008 | 01:21 PM
Most Cat's used as pleasure boats turn the props out becasue it gives the boat better handling. Turning them in willl give you an extra 1 or 2 Mph but is a little more of a handful. My 2002 Motion with 300x's had the props turning in. My 2003 Motion with 2.5's has them turning out.
The X dimension should be 1.5 to 1.75 above the running surface.
What props do you have on the boat? How much fuel were you carring? How many people were with you?
Old 06-30-2008 | 01:52 PM
15x30 labbed cleavers,1/2 tank each side,1 passenger,hot and humid.
Old 07-03-2008 | 11:20 AM
2 Trick Rick's Avatar
Racer
What rpm are you spinning?
2 Trick Rick is offline
Old 07-07-2008 | 06:52 AM
about 6500
Old 07-07-2008 | 01:32 PM
Racer
Thats 11% slip.. I'm not sure whats a normal slip ratio on a cat. I know I have mine down to 9% now and I'm not sure if I can do better.
Old 07-07-2008 | 02:24 PM
what are you spinning for props?
Old 07-07-2008 | 04:13 PM
Racer
15X25 Hydromotives at 8200/8300 rpm. 83/84mph
