Fuel Pump and Reg support 1000 H.P. >
Old 06-30-2008 | 10:04 AM
Sick Stinger's Avatar
Brotherhood #1
Default Fuel Pump and Reg support 1000 H.P.
Looking for an eltric fuel pump and reg to support high H.P. I have a holley back and have to keep the pressure real hight to keep the fuel there. I dont know the best option but im thinking aeromotive. Let me know
-Mike
Sick Stinger is offline
Old 06-30-2008 | 04:15 PM
RMPRam's Avatar
I have twin 1100hp PSI supercharged motors in my 38 Cigarette. I use a modified manual, 6 valve, fuel pump for normal cruising and have 2 Weldon marine electric pumps augmenting the mechanical pumps under boost. The Weldons are hooked to a hobbs pressure switch that is triggered @ 4lbs of boost/pressure to "come on". I have lights on the dash to indicate when the el. pumps are "on" and I monitor the fuel pressure guages when I'm under boost to see that all is well. Hope this helps.
Gary
RMPRam is offline
Old 06-30-2008 | 06:39 PM
Brotherhood #1
Thanks Gary. Im looking to run one pump with a boost referance pump. I had a guy PM somethign that looks like it will work its an SX pump and reg. the reg is pressure monitored to allow more fuel when needed (i assume).
-Mike
Old 06-30-2008 | 08:42 PM
Elite Marine's Avatar
I have run the Aeromotive Black pump, filter and regultor on my TPI 1100 with no issues.
Elite Marine is offline
Old 06-30-2008 | 08:47 PM
Turbojack's Avatar
aeromotive makes a pump called the eliminator. That one works good for me.
Turbojack is offline
Old 07-01-2008 | 07:31 AM
Brotherhood #1
i will look in to them thanks guys Elite do you sell the aeromotive stuff
Old 07-01-2008 | 09:22 PM
Default pumps
I have six pumps two new 140's $500 two used 250's for $200 two180's for $200
kidapache is offline
Old 07-02-2008 | 12:26 PM
Brotherhood #1
140's wont support it i have a 140 now
Old 07-02-2008 | 04:22 PM
I have 1100hp with one 110 meachanical and a 140 electric pump reg set at 8psi
Old 07-02-2008 | 05:57 PM
Brotherhood #1
I only want to run an electric with a boost refeance reg
