700 SCi Question.
Old 06-30-2008 | 05:48 PM
Chuck's Avatar
Default 700 SCi Question.
After running the boat hard the starboard motor seems to rev betwwen around 700rpm to about 1200 rpm when in neutral. It is hard to notice because I have the quiet exhaust and when I am using the sticks to dock the boat I am banging the trans. hard when shifting. Has anyone else had this condition? What was the problem and remedy? Thanks.
Chuck is offline
Old 06-30-2008 | 08:37 PM
Jassman's Avatar
No problems of any to date Chuck..but I only have 60 hours on them.
Jassman is offline
Old 06-30-2008 | 08:47 PM
Rcrapsey's Avatar
Get Down
Not so far I have 130 hrs.
Rcrapsey is offline
Chuck's Avatar
Your ahead of me. Time to trade her in
Chuck is offline
Old 06-30-2008 | 08:54 PM
throttle cable adjustment maybe.
cantoon is offline
Old 06-30-2008 | 09:44 PM
Throttle cable? On a fly by wire control? I don't think so.
pasquesi is offline
Old 06-30-2008 | 10:56 PM
IAC issue? Get a scanner on it.
TxHawk is offline
Old 07-01-2008 | 04:25 AM
GLH's Avatar
GLH
Obviously something is iffy on an EFI engine, get it checked. Call Bob here he might know...802-658-2353
On carbbed blower engine I would tell you it's the surge and shift just before the upswing surge. Ahh the joys of blower engines!
GLH is offline
Old 07-02-2008 | 07:07 PM
Brent Medley's Avatar
Question
One of my 500 EFI's w/Whipple supercharder does the exact same thing.......swapped the IAC from the other motor and it does the same thing.........I'm stumped also
Brent Medley is offline
Old 07-02-2008 | 07:15 PM
Whipple Charged's Avatar
The only fly by wire on the engine is for boost control and equalizing pressure above and below the sc.
I would certainly double check the linkage and make sure it's closing to the same spot everytime. Sometimes the cable gets bound and that last 2% doesn't close all the time. I run just a touch of pre-load on the linkage, therefore they close in the same spot every single time. If you set them up in a "neutral" position, they will tend to not repeat, and thus you could have a high idle situation.
Computer has a code for a IAC fail, doubt thats the case.
Dustin
Whipple Charged is offline
