Holley 800cfm rebuild kit? >
Old 07-01-2008 | 06:05 PM
CAPTAIN CHUCK's Avatar
Default Holley 800cfm rebuild kit?
Where can I get a rebuild kit for my Holley 800?
It's the stock carb on one of my 1996 500 HP's.
Thanks.
CAPTAIN CHUCK is offline
Old 07-02-2008 | 12:58 PM
Anyone?????
Old 07-02-2008 | 03:48 PM
Whats bad in it???? You should just be able to take the old gaskets into an auto shop and match them. All the parts are available separately. I have always juut bought what I needed separately.
Griff is offline
Old 07-02-2008 | 03:57 PM
I am not really sure what is bad in it.
I had a problem with some water in my fuel so I was told it may have clogged the carb in some way.
The boat ran fine last time out and now, 2 weeks later, the starb motor won't start....
I am playing the guessing game basically.
I am going to switch carbs on my first day off and see if this is the problem....if not then it's back to the drawing board....
Old 07-02-2008 | 04:52 PM
Thanks.
Hey Bro JEGS, or SUMMIT
Old 07-02-2008 | 05:00 PM
Now if that fixes the problem I will be a happy camper er boater...
Old 07-02-2008 | 06:11 PM
The rebuild kits are cheaper then a few lap dances , you may as well order 1 out and have it in the tool box . Now back to the Goose & cranberry
Old 07-03-2008 | 01:00 AM
If its just clogged with some debris, you will only need the gaskets and replace the PV for good measure.
That should not make it not start at all though. It should at least start and maybe run rough. I'm guessing your plugs could be fouled.
I have had water in my fuel and that will make it not start once the water sep filter fills up. Dump the filter into a clear glass and check for separation. Water will be on the bottom. If there is water refill the filter with fuel and reinstall. I would try that first and then check the spark plugs, before I would switch carbs.
Griff is offline
Old 07-03-2008 | 05:39 AM
boatme's Avatar
Two cans of carb cleaner, a complete rebuild kit, and alot of patience
I just went through this I was one day away from blowing $500 for a new carb I was so frustrated
Found the smallest piece of crud behind the float, under the seat that i had not gotten blown out on the prior four tear downs last week
Amazing how bad things work with just a tiny piece of crap hiding somewhere
boatme is offline
Old 07-03-2008 | 05:43 AM
boatme's Avatar
http://www.holley.com/
Holley Tech Service 270-781-9741
boatme is offline
jvschlegel
12
03-26-2008 09:28 PM
375stinger
7
11-28-2005 08:07 PM
blue thunder
22
01-08-2004 04:48 PM
dyno
7
09-17-2002 08:44 PM
MrCIG
2
05-13-2002 11:35 PM
