Single or dual Carbs on a blower?
Hi guys. I have a hp 500 with a Weiand 256 blower, dual holley 660 race carbs. I was looking at changing out the duals for a single dominator but am not sure if I will get enough air/fuel to the motor. Would it be more efficient with a single or should I stay with the dual 4 setup? Thanks.
if these are the tunnel ram center squirter 660's I would get rid of them on a boat...not very low end friendly and like to kill plugs when docking etc. the single dominator would work fine, being set up right....or run a pair of 600 or 650 reg double pumpers set up for a blower( boost referenced power valve and jetting) Rob
How much do you think I would restrict performance by going with a single dominator? I would rather go to a single carb but don't want to sacrifice performance. What are you referring to when you "boost reference" the carb? Is this something that needs to be done?
I have a guy down here that is very reasonable. He was the head Holley tech at Davinci carbs before they shut down.
Builds a really nice cusom unit for around the same price as a new one, and sometimes a little less.
PM me and I'll get you his number.
