Prop Setup
Old 07-14-2008 | 06:10 PM
Default Prop Setup
What would your thoughts be on the correct prop setup for a:
37' single step
620 hp side by side motors
bravo's with no boxes
32fever is offline
Old 07-26-2008 | 08:56 PM
these were set up from the factory with Hydromotive 4 blade thru hub props, in the 27 - 28 pitch range with a 1:50 gear
Snakebite A-82 is offline
Old 07-27-2008 | 08:43 PM
Pit's Avatar
Pit
37' single step
Try a set of 30 pitch 4 blades spinning in.
Pit is offline
Old 07-28-2008 | 05:22 PM
all 37 side by side were set up spinning out for maximum transom lift...the 37 single strp carried the nose naturally
Rambunctious
07-22-2019 12:09 PM
jgipson
Prop Talk
4
07-12-2007 10:07 AM
Megabite
Prop Talk
1
05-30-2007 12:28 PM
East Coast B
Sonic
19
04-28-2005 05:17 AM
