How much hp are you making with a 4150 base carb? >
Old 07-16-2008 | 08:21 AM
Nordicflame's Avatar
Default How much hp are you making with a 4150 base carb?
It seems that 700hp in 565-588ci motors is the fence for high flowing (1000cfm+) 4150 carbs before venturing into 4500 Dominator territory.
I'm just curious if anyone has some good dyno numbers running a 4150 base carbs of the HP1000 variety. It seems to be agreed that the 4150 base carbs are more fuel efficient and user friendly in a pleasure/performance application than their counterpart Doms. The Holley chart says the HP1000/4150 is the selection for 600ci/6000rpm motors.
So why does everyone like the Dominators? It seems that giving up 10-15hp on top is a small price to pay for increased efficiency and mannerism across the board.
Normally I'm an EFI guy so this is somewhat new to me.
I have the opportunity to go either way here (4150 or 4500) with what I have so I'm just trying to learn and make the bst choice.
Thanks,
Dave
Nordicflame is offline
Old 07-16-2008 | 10:48 AM
700 + h/p is not a problem for 4150's as most of the marine engines are on the low side when it comes to rpm, and yes the circuts are better for marine use as well...Rob
ezstriper is offline
Old 07-16-2008 | 12:24 PM
http://www.pro-system.com/
VERY godd carb guy.
Car Biz is offline
Old 07-16-2008 | 12:30 PM
Strip Poker 388's Avatar
Rob
My dominator's ran better than my 4150's
They make a 3 circuit dom
Strip Poker 388 is offline
Old 07-16-2008 | 12:33 PM
Yes, I have spoke with Patrick...
Old 07-16-2008 | 12:39 PM
Thanks Strip...
I'm a bit confused on the 2 vs 3 circuit. All previous discussion (and Bob Teague) think the 2 circuit is the only way to go???
Dave
Old 07-16-2008 | 04:11 PM
you do NOT want a 3 circut dominator, I got one for my top sportsman car after talking to holley, worked like crap..called back a couple of times before we figured out that we were not leaving the starting line on the floor on the trans brake ! only at 3000, any way a 3 circut carb is only designed for drag racing with a trans brake leaving flat on the floor...the other circut makes up for the lack of accel pump which is passed by at that point...I had to convert mine to a 2 circut and works great now...lots of mis conception on these carbs...Rob
Originally Posted by Nordicflame
Thanks Strip...
Dave
I think the majority of newer Dominators are 3 circuit. Nickerson blocked off of one of the three circuits on my Dom.
Kidnova is offline
Old 07-16-2008 | 08:21 PM
jdnca1's Avatar
I made 900HP NA pump gas with 4150 style carbs....of course (2) helped....
jdnca1 is offline
Old 07-17-2008 | 07:19 AM
they make both 2 and 3 circut ones, many different applications
