Blower question >
Blower question
Blower question
Old 07-17-2008 | 07:59 PM
Default Blower question
Is this a good setup for a hp 500. Sorry if this is a dumb question but i am just not to sure when it comes to blowers.
250 B&M BLOWER COMPLETE SET UP
BLOWER, INTAKE, NEW 2-4 CARB PLATE NEW 2-4 LINKAGE 2 GAFFRIG SS FLAME ARRESTORS 2 SS FUEL LINES 2 750 HOLLEY CARBS
if this wont work can someone please tell me what will work so i can keep an eye on ebay and opther sites. or if it would be better to just do heads and cam. Thanks Jeramy
ubet28 is offline
Old 07-17-2008 | 08:17 PM
aTX427's Avatar
Whipple EFI all the way
aTX427 is offline
Old 07-17-2008 | 08:23 PM
You'll make 600+ all day long and 5 lbs of B@@st if thats what your lookin for good luck
Old 07-17-2008 | 08:46 PM
so is this a good candidate for my motor. or is there a better choice? Or would it be more realistic to do heads and came?
ubet28 is offline
Old 07-17-2008 | 09:11 PM
I run 250's on my engines and really like them. I would think you would be happy with them on your 500 HP's. My only suggestion is make sure you get your carbs dialed in. If your carbs are set up right you it will idle and run great for you.
Good luck.
GS42fun is offline
Old 07-17-2008 | 10:37 PM
I would suggest BLOWER SHOP blowers. The end pieces are all billet...not cast like B&M or Holley...a far superior unit for about the same money. Call Rick Bourns at CP Performance
( www.cpperformance.com ) and he can fix you up.
pslonaker is offline
Old 07-17-2008 | 11:32 PM
Since it sounds like your loking at a used set up, try the classifieds. There were two merc 420 set ups ( complete) for sale. Those are suted to the 500 even better than the 250's, due to it's ability to make good boost at a slower rotor speed. Probably not a big difference in price also.
Darrell.
DMOORE is offline
Old 07-18-2008 | 12:31 AM
handreasen's Avatar
Made 645HP with 502 / 8.75/1 comp, dart 2 al heads, lunati cam, 7# boost, intercooler, v6 thunderbolt module for a total of 27 degrese for total timing. Ran 91-93 oct in winter months and AV gas in summer. Over 175 Hrs on motor till I sold boat. Had pyrometers on each side and watched egt's carefully.
handreasen is offline
Old 07-18-2008 | 12:46 AM
Whipple Charged's Avatar
Blower is pretty small, would be a lot better off with larger sc or more efficient.
Dustin
Whipple Charged is offline
Old 07-18-2008 | 01:08 AM
Buy adding the blower do i have to have the hood scoop? Cause i am not wanting that look of a hood scoop coming out my backseat. Also is the 420 on the classifieds a good set for me.
ubet28 is offline
