Blower question >
Blower question
Blower question
Old 07-18-2008 | 07:01 AM
I am running a 454, 1/4 stroke, 482, KB blower pistons, comp blower cam, mild ported oval port 781 heads, weiand 177, 4.5 lbs of boost, 850 holley, 525hp @ 5500..Rob
ezstriper is offline
Old 07-18-2008 | 10:32 AM
What about this setup better choice?
B&M 420 polished Mega-Blower, Set up for Big Block Chevy. Comes complete with all pulleys, intake, brackets, Bary Grant Carbs, Linkage, Regulators, partial fuel lines (Steel Braid), & functional Mechanical Scoop. Immaculate condition!, Aleays stored inside,
ubet28 is offline
Old 07-18-2008 | 10:55 AM
Airpacker's Avatar
needs a cooler whch means longer studs and belt to go with it. The studs are available from Teague for 75 bucks. Cooler around 1500.
Airpacker is offline
Old 07-18-2008 | 01:10 PM
Whipple Charged's Avatar
420 is certainly better than the 250, on a 500hp. An intercooler is a good idea either way. Motor has cast iron heads and 8.75:1 compression. Non intercooled, 420, keep boost to 4-5psi, should make 625-650hp. Add intercooler, you can go to 6-7psi and make 675-700.
Thanks,
Dustin
Whipple Charged is offline
Quaid24
03-26-2007 08:14 PM
nocigarette
17
10-07-2006 04:29 PM
drewwilliams
7
06-08-2006 06:45 PM
ssherman
06-11-2002 02:16 PM
puder
17
02-27-2002 08:56 AM
