496 help needed.
Registered User
Anyone have the torque sequence for the 496 MAG HO cylinder heads? Appears that i can not find it anywhere online. Installing the cometeic gaskets but I do not have the torque pattern.
Thanks.
Thanks.
Registered User
THanks for the Pic. Get the gaskets in & torqued. Now lets see if the darn thing actually runs. Had some issues when removing the original Intake manifold to install a Whipple. An intake manifold bolt broke off in the cylinder head just below the boss. Then, while drilling the center of the bolt & trying an easy out. The easy out tip broke off. Well after conteplating the mess I figured now would be a good time to remove the cylinder heads & have a machine shop remove the broken bolt & easy out while installing the cometic gaskets to go with the WHipple. Hopefully it'll still run after all the work!
