Cubic Inch Displacement formula question? >
Old 07-19-2008 | 10:39 PM
Default Cubic Inch Displacement formula question?
Please help me figure out what I'm doing wrong.
A 454 engine is= 4.250 diameter X 4.000 Stoke.
If you multiply 4.250 X 3.144 (pie)=13.362
13.362 X 4.000 (stroke)=53.448 cubic inches per cylinder
53.448 X 8 Cylinders =427.584 cubic inches, not 454.
What am I doing wrong?
I have a rebuilt engine with a 4.250 stroke and 4.250 pistons, I'm told its a 482, but using the math fomula above, it doesn't work out?? 4.250 x 3.144 x 4.250 x 8=454.308 cid.
Thanks for your help!
Fast Shafts is offline
Old 07-19-2008 | 10:43 PM
area is pi* radius squared
beck427 is offline
Old 07-19-2008 | 10:56 PM
Beck,
Could you please explain your post??
Old 07-19-2008 | 11:24 PM
2.125x2.125x3.14=14.179
14.179x4.0=56.79
56.79x8=453.73
dzglaser21 is offline
Old 07-19-2008 | 11:32 PM
take the diameter of your piston and divide it by 2, this will give you the radius. square the radius (multiply it by itself ie: 2.125 * 2.125 = 5.516) take this number and multiply it by pi. you now have the area of the piston, for volume you just need the height so multiply that by your stroke. now just multiply that by your number of cylinders and you will have displacement.
3.14 *(2.125^2)= 14.179in^2 <--- area of the piston
14.179*4= 56.716in^3<--- volume of the cylinder
56.716*8= 453.73in^3 <--- Displacement your engine
beck427 is offline
Old 07-20-2008 | 01:14 AM
I use a little different formula.
Bore X Bore X stroke X 6.2835= cubic inches
4.25 X 4.25 X 4 X 6.2835 = 453.982875
Eddie
Young Performance is offline
Old 07-20-2008 | 08:46 AM
Registered User
Formula for the volume of a cylinder-
1/2 the diameter of the bore (radius) multiplied by itself (squared, times 3.14 (pi)
Then-
that result times the stroke- that's individual volume
Then-
Multiply by the number of cylinders.
Example-
4.25" bore and 4" stroke
Divide 4.25 by 2= 2.125, times 2.25= 4.516.
Now multiply by pi- 4.516 times 3.14=14.18
14.18 times stroke (4) = 56.72
56.72 times 8 cylinders gives you 453.76 ci
Eddie's formula is simpler, but I can never remember it. I can remember pi. Because my 5th grade teacher beat this into me- "Pies aren't round, pi are square"
Chris Sunkin is offline
Old 07-20-2008 | 09:04 AM
spazboz's Avatar
bore x bore x stroke x .7854 x number of cylinders= CID
In the case of a 454 Chevy:
4.25 x 4.25 x 4.00 x .7854 x 8 = 453.9612 cubic inches
spazboz is offline
Old 07-21-2008 | 06:56 AM
Hell just ck the numerous bore/stroke charts out there...far easier !!!
ezstriper is offline
bcfountain
Fountain
9
08-14-2007 02:17 PM
Strip Poker 388
02-11-2007 09:25 PM
FASTERDAMITT
04-27-2005 04:32 PM
GPM
19
02-12-2005 08:08 PM
SinkorSwim
28
12-11-2003 11:38 AM
