Demon Carbs With No Way To Hook Up >
Old 07-21-2008 | 06:53 AM
TRYME's Avatar
Registered User
Default Demon Carbs With No Way To Hook Up
Is There Anyone Out Here Using Demon Carbs?
How Did You Hook Up Trottle Cables, Can't Use Rocherster Bracket Anymore.
Was Demons Worth The Headache Of Changing?
TRYME is offline
Old 07-21-2008 | 08:01 AM
Holley makes a bracket that works. You may still have to do a little finess around the accelerator pump arm. A friend of mine is using one and it seems to work well. He likes it.
Tow-N-One is offline
Old 07-21-2008 | 10:14 AM
Yep use the holley bracket that is what I have on mine and it works perfectly.
x7734x is offline
Old 07-21-2008 | 12:38 PM
boatman22's Avatar
Agree with others..holley bracket works great. I have 2 Demons on mine and worth all the effort
boatman22 is offline
Old 07-22-2008 | 11:36 AM
TRYME's Avatar
Registered User
Thanks Guys Will Try To Get It Through Summit
Anyone Have A Part Number Or Is There Only One?
Thanks Again
TRYME is offline
Old 07-22-2008 | 12:01 PM
CPPerformance's Avatar
Available in a assortment of colors to match your engine compartment http://www.cpperformance.com/detail.aspx?ID=1081
CPPerformance is offline
Old 07-23-2008 | 12:26 PM
Velocity Vector's Avatar
Crazy Energy
I shop CP cause it is a one stop shopping and you get to talk to people that know what you want and the stuff you might forget. Good stuff Maynard!
Velocity Vector is offline
Old 07-23-2008 | 08:59 PM
TRYME's Avatar
Registered User
JEGS HAD EVERYTHING IN STOCK I SHOULD HAVE IT FOR POKER RUN SAT
I ALMOST FORGOT FUEL LINES TOO
TRYME is offline
Old 07-28-2008 | 10:33 PM
I have a demon 850 with the red replaceable venturis.
AWESOME
Frankly the holley 850 has a crappy signal, and compared to the demon (any demon) is a complete POS.
The Demon makes more power, gets better mileage, idles better, more responsive throttle, better low end, midrange, and top. - get the idea?
It was completely worth the hassle, but for whatever reason I had no hassle the model I got bolted right to the Holley bracket no problem.
Uncle Dave
1991 20.8 Laveycraft Sebring Tunnel
406 small block
Bravo 1 XR
Mercury ITS
polished Imco powerflows
Hot Boat Magazine calendar sept 1993
Tested Powerboat Magazine June 1993 by Bob Nordskog
<about ready to buy a new 2750>
Uncle Dave is offline
Donzi Black Widow
12
11-02-2004 12:02 AM
klaw
06-22-2004 12:01 PM
WALKIN THE DOG
3
06-03-2003 05:39 AM
DanB
27
01-06-2003 05:05 PM
fred
3
09-18-2002 05:39 AM
