What kind of sea pumps are these? >
Old 07-22-2008 | 10:29 PM
Nordicflame's Avatar
Default What kind of sea pumps are these?
Can anyone ID these?
Thanks,
Dave
Attached Thumbnails What kind of sea pumps are these?-dsc03358.jpg   What kind of sea pumps are these?-dsc03359.jpg
Nordicflame is offline
Old 07-23-2008 | 06:07 AM
Mbam's Avatar
Offshoreonly Advertiser
I'ts a Mercury, was used before the current 2/3 piece style.
Uses the same impeller, bearings & seals as the newer one.
I think I still have a couple of them floating around.
http://www.mercruiserparts.com/Show_...+PUMP+ASSEMBLY
Mbam is offline
Old 07-23-2008 | 07:04 AM
Thanks Marc...
They look pretty good actually and how would it be to change the impeller with only removing the rear plate and not everything else
I would assume the pressure output would be the same assuming the same impeller.
What would I need to rebuild these other than the impeller obviously? Any special tools?
Thanks,
Dave
Old 07-23-2008 | 03:31 PM
All you will need is an impeller, unless it has a bad seal and is leaking. It uses the same impeller as the newer pumps and you don't need any special tools.
Eddie
Young Performance is offline
Old 07-23-2008 | 03:37 PM
Thanks guys...!
tomcat
16
06-12-2007 04:36 PM
G Man
5
10-07-2005 11:06 PM
chuckgo6
4
09-12-2005 10:40 AM
dyno
3
06-06-2005 11:50 AM
