World Merlin ( Teague 509 block) >
Old 07-25-2008 | 08:25 AM
RICHARD CUNY's Avatar
Default World Merlin ( Teague 509 block)
Good morning group
Once again I need som help Last week I had a ring gear and new starterinstalled and it lasted only three days are there any issues with this applaction any one experianced this.
Rich
RICHARD CUNY is offline
Old 07-25-2008 | 09:39 AM
johnnyboatman's Avatar
What Starter R U Using
johnnyboatman is offline
Old 07-25-2008 | 11:30 AM
when you turn the engine over how does the starter sound ? any grinding weird noise ? did you replace the starter when you did the ring gear...you should have if you didn't. if it sounds weird or grinds, you have to shim the starter, not uncommon on gm's, also you need to make sure you are running the correct starter for you flywheel, gm did make a couple different ones...did you change anything just before any of this started ? Rob
ezstriper is offline
Old 07-25-2008 | 03:42 PM
I Had A Very Good Shop Replace The Ring Gear And A New Starter No Other Work Im Not Sure What The Replaced Orignal With But I Will Know Monday.
Rich
RICHARD CUNY
10
08-30-2008 11:56 AM
RICHARD CUNY
4
07-26-2008 10:08 PM
HARDCORE A/O
11
06-17-2005 11:58 AM
Firewalker
15
07-01-2003 01:51 PM
gofastwannabe
0
03-31-2002 10:10 AM
