Oildyne Trim Pump Question >
Old 07-31-2008 | 11:31 AM
Default Oildyne Trim Pump Question
My 1998 2.5 ROS trim system looses pressure after time. The system uses the Oildyne trim pump. I switched the current pump with the other pump in the boat and it seems to be holding pressure. So, the problem is somewhere inside the old pump.
Are the Oildyne pumps rebuildable? What normally casues the pump to go bad? Is it just a couple of orings that go bad?
Any help would be great!
Thanks!
Don
Maritime_Eng is offline
Old 07-31-2008 | 11:50 AM
Not sure if this will help but here is an oildyne service manuel pdf I found...
www.boatfix.com/merc/Servmanl/11/11a5r5x.pdf
bigo181979 is offline
Old 07-31-2008 | 11:58 AM
Good find! Thanks!
ratman
04-16-2006 11:32 AM
ratman
01-26-2006 07:48 PM
tcelano
3
05-17-2005 09:36 PM
218diver
1
06-23-2004 11:50 AM
later
6
07-01-2003 08:31 AM
