Drives hitting swim platform. >
Old 07-31-2008 | 08:13 PM
Default Drives hitting swim platform.
My drives will hit the platform when all the way up.. Is there a way to stop them from hitting? Like a safety or something. Bravo XR's
Carguy08 is offline
Old 07-31-2008 | 08:54 PM
I had this problem with my Pachanga when I switched from an alpha to a bravo. We set the trim limiter for trailering. Just can't use the trailer buttom and have to be careful not to overtrim.
pachanga is offline
Old 07-31-2008 | 10:07 PM
I looked in the new Merc shop manual and it states:
"to avoid hitting swim platform with outdrives while trimming up, lift finger off trim switch before the outdrive hits the swim platform"......
thedonz is offline
Old 07-31-2008 | 11:00 PM
Inside the trim rams, there are plastic spacers that can be added. I had to add one more to mine when I switched to different top caps.
Darrell.
DMOORE is offline
Old 07-31-2008 | 11:06 PM
For the $ you spend on a nortech ,i would call tron and have him modiefy the swimplatform.
Or like the donz said ,dont trimm to high.
Put a mark on the indicator then you know how high you can go .
DareDevil is offline
Old 08-01-2008 | 12:51 AM
Like I said earlier, the spacers inside the rams are missing. It's a simple install.
Darrell.
DMOORE is offline
Old 08-01-2008 | 07:38 AM
my daytona had the same problem (the 1st owner bent the tie bar) had one spacer per ram BAM saidhad another one they sent me the spacers I installed them and no more problems also but the tool to take of the caps good $ spent
eliminatethis is offline
Old 08-01-2008 | 09:07 AM
I also had to add spacers inside the rams when I swithed to a X-Drive. I ended up buying two sets to stop the travel.
They where like $5 a set from Merc. I asked if they where missing a ending 0 zero I can't remember the last time I purchased anything from Merc for $5. Adding the spacers only takes a few minutes. I ended up making my own spanner wrench also when I saw the price for one.
1BIGJIM is offline
rooster
04-22-2007 10:21 PM
psmith
Chris Craft
3
07-31-2006 06:15 PM
rch662
Superboat
0
01-25-2006 02:17 PM
wrinkleface
Fountain
1
09-20-2005 09:54 AM
THRILLSEEKER
05-27-2002 03:44 PM
