P5Xs vs Precision Props >
Old 08-02-2008 | 12:20 PM
Rebel_Heart's Avatar
Default P5Xs vs Precision Props
I have had a set of labbed P5Xs for a season (labbed by Bblades) and wanted to compare with the 5 blade Turbo props from Precision. The Turbos were not labbed. I ran with a lot of humidity, slightly rough water with only 10 minutes in-between runs (enough time to change props). I wanted to see if i could get above 5500 rpms, as my dyno sheet says I should be turning at least 5800.
P5Xs - 96.5
Turbos - 94
The turbos had a little more speed at any given rpm, but felt a little less responsive (probably because of labbing of the P5Xs). The Turbos turned the same rpm (5500). Still trying to reach a higher rpm.
We tried taking the diffuser ring off the P5Xs and the boat wouldn't get on plane. I wonder if some of the diffuser ring coiuld be removed, it has a big flare.
Rebel_Heart is offline
Old 08-04-2008 | 08:10 AM
P5Xs - 96.5
Turbos - 94
What pitch turbos were you trying?
Brett has my Precisions close to done, hopefully will have them back to try the lab version by the end of the week. I hope this deal gets the speed back with these props, guess I just have to trust the man and his abilities.
RaggedEdge is offline
Old 08-04-2008 | 11:21 PM
They were the 30s. I think these were the same ones that you have?
Old 08-05-2008 | 07:34 AM
Mine are 30s and being reworked now. Have you ever run the Hydro P5s, not the Xs, and how did the work on your boat?
Old 08-05-2008 | 11:24 PM
Never had a chance to run the P5s. Tom wouldn't let me try both, so I went with his recommendation. He said the P5s were for the extremely high x-dim. Would have liked to have tried, though
Let us know how your labbed Turbos come out? They looked like there is plenty of material to work with.
Old 08-06-2008 | 11:41 AM
Does Hydro have a test program? How does it work?
Still waiting on the Precisions, will post results at some point. I'm hoping things turn out well.
Old 08-07-2008 | 08:05 PM
KAAMA's Avatar
Both props were 30" pitch?
KAAMA is offline
Old 08-08-2008 | 02:49 AM
The P5X was a labbed 31. When I put them side by side, a noticeable difference in the amount of material on the Precision. Brett had labbed the P5Xs down, thinning the blades. I would imagine he'll do something similiar to the Precision props.
Hydro didn't have a trial program. You buy the prop, then send back to be labbed. I wanted to try the P5Xs and P5s back to back, but Tom wouldn't let me try more than one prop without buying both.
I think Brett may have the only true trial program.
Rebel_Heart
Prop Talk
3
05-28-2008 05:23 PM
Rebel_Heart
Fountain
29
07-07-2007 04:34 PM
t500hps
06-11-2007 06:47 PM
BY U BOY
07-09-2006 04:34 PM
panteraman28
08-13-2004 08:23 AM
