trim tab wiring
Old 08-02-2008 | 06:15 PM
Default trim tab wiring
anyone know what recommended wire size and fuse are for trim tab pumps? I thought I recalled seeing a 50amp fuse in an old post. Seems pretty large. Wire runs are about 4-5 feet direct to battery.
thanks
sabercatt is offline
Old 08-07-2008 | 07:52 PM
offthefront's Avatar
#10 Wire ... 20amp
offthefront is offline
Old 08-07-2008 | 08:14 PM
thank you. just bought some #8 the other day, so I'm in good shape!
Old 08-24-2008 | 01:48 AM
sunchaser796's Avatar
8 gauge wire is fine for the trim and drive pumps.There should be a 90 amp fuse block install on the solenoid post on both pumps. 20 amp fuse to power the your dash switch. Good luck with it.
sunchaser796 is offline
bleachers
4
07-15-2008 11:18 AM
26sonic
04-30-2008 03:08 PM
wet_rat
Sea Ray
7
09-16-2007 04:38 AM
26sonic
Sonic
8
05-12-2006 09:23 PM
Monty
6
05-16-2005 01:24 PM
