Help, Trim Tab Wiring >
Old 07-15-2008 | 06:57 AM
Cool Help, Trim Tab Wiring
It has been so long since i removed my engines from my 38 sonic that in reinstalling, i have forgotten were the long red wire coming off the oump for the tabs goes. it is long enough that i beleive it goes to starter solenoid, just wondering if anyone knows for sure
bleachers is offline
Old 07-15-2008 | 08:32 AM
Wally's Avatar
Were doomed!
That red wire needs 12V+ batt power....if its long enough to reach the starter then connect it to the batt cable...if you can go straight to the battery, even better.....or if you want to be able to have the batt's isolated when the boats not in use, run the red wire to the output of your 1/2/both switch.....
-Wally
Wally is offline
Old 07-15-2008 | 09:12 AM
PatriYacht's Avatar
Mine goes to the starter positive where the battery cable attaches. My pump has a circuit breaker on it.
PatriYacht is offline
Old 07-15-2008 | 10:15 AM
thanks, i thought that is were it went, to the starter, does it go on the same side of the solenoid as the little starter wire on on the other small pole?-- i have so much to reassemble that i am getting brain freezes
Old 07-15-2008 | 11:18 AM
jhiguy377's Avatar
No, I believe that wire is energized only when you engage the starter. You really want the trim pump to have continuously available power whenever your safety main switch(es) are on. Good luck- Jeff
jhiguy377 is offline
sabercatt
Do It Yourself, Boating on a Budget
3
08-24-2008 01:48 AM
26sonic
04-30-2008 03:08 PM
wet_rat
Sea Ray
7
09-16-2007 04:38 AM
26sonic
Sonic
8
05-12-2006 09:23 PM
Monty
6
05-16-2005 01:24 PM
