Good Experience with PirateCom
There has been a lot of negative reports about various businesses lately. I just wanted to say that Romeo and Larry from PirateCom are a great company to do business with. I put an Extreme 4 person wired intercom in my Fountain. I did the installation myself. It was very easy to install, basically plug and play. Other than an issue with where I installed the receptor plugs for the headsets, it works great. I originally purchased the over the head model headsets and found that mine lifted at higher speeds especially when I am standing. I talked to Romeo and he sent 2 behind the head model headsets and said to try them to see if I like them better. He sent these N/C and only asked that I ship the 2 unused original headsets back if I liked them better. I did like these better and they do not lift at high speed (80 plus). I thought it was cool that he trusted me to send them back and he has taken very good care of us. Their system is reasonably priced and works very well. My wife and granddaughter use the system on all longer runs and it is nice to be able to communicate between us especially during poker runs.
The only advice I would give after installing and using the Extreme system is think carefully where you are going to locate the plug receptors for the headsets. The plugs are designed to break away in case of an emergency and are fairly fragile. Don't put them where you might bump them with your knee or arm cause they will break. I learned the hard way. First trip out my granddaughter leaned on one of the plugs and I had to replace it and move it to a better more protected area and had to think of a creative way to cover the hole.
Top Banana
03-19-2005 08:56 PM
Bo Knows
07-06-2002 09:46 AM
