Cooling down the Merc Trans >
Old 08-14-2008 | 10:41 AM
Default Cooling down the Merc Trans
I have been told to directly route the discharge side of the merc trans cooler thru the transom instead of thru the exhaust manifold. Sounds simple enough.... Anyone have a suggestions / comments on this or pics? I'm always a bit nervous when it comes to drilling holes in my boat.
Wsh3marine is offline
Old 08-14-2008 | 11:13 AM
It is highly recommend vs. running the discharge out the exhaust. I ran both of my discharges out the same side...I can take a quick look and at my cooling water flow and know I am pumping water. I got some nice tru hull S.S. fittings from Eddie marine that were for 3/8th hose and they look great.
Westcoast is offline
Old 08-14-2008 | 12:05 PM
98itrwhite's Avatar
a little of topic but how much hp. are you guys putting through those merctrans?
98itrwhite is offline
Old 08-14-2008 | 01:35 PM
So you went out the side (I'm assuming the right side) near your bilge thru hull?
Thanks for your reply[
QUOTE=Westcoast;2653542]It is highly recommend vs. running the discharge out the exhaust. I ran both of my discharges out the same side...I can take a quick look and at my cooling water flow and know I am pumping water. I got some nice tru hull S.S. fittings from Eddie marine that were for 3/8th hose and they look great.[/QUOTE]
Old 08-14-2008 | 01:36 PM
Just stock 454/330HP
Old 08-14-2008 | 03:05 PM
Mine are run with 3/8 thru hole out the transom near the exhaust.
GoFastSonic is offline
Old 08-14-2008 | 08:24 PM
330's w/holleys and HEI.
Old 09-09-2008 | 05:21 AM
Bill,
I have dry pipes so all my water discharges through the black fittings you see in the picture. As I rebuild the boat these are being replaced with SS through hull fittings.
...Jim
502ss is offline
olredalert
Swap Shop
15
11-09-2008 11:59 AM
GoFastSonic
Drives and Lower Units
5
02-29-2008 01:26 PM
GoFastSonic
01-28-2008 03:11 PM
excaliber
8
01-23-2003 07:05 AM
hystat
2
05-27-2002 05:35 PM
