28 daytona
Old 08-15-2008 | 11:39 PM
Default 28 daytona
Anyone know what a 1999 28 daytona weighs? What's the hp/top speed ratio on this hull, approx? Slip %?
How fast would you expect this combo to be: 1999 28 daytona, 540ci with 12-71 blower, brodix aluminum heads, 8.5lbs, bmax 1.3 drive, and 28 bravo? At 850 hp around 100 maybe?
Goin for Elim number 2, hopefully...Thanks
Yellow_ICC_OK is offline
Old 08-17-2008 | 05:28 PM
gsmith9898's Avatar
If its a td I would guess 80-85 and 2 drives a summer.
gsmith9898 is offline
Old 08-17-2008 | 06:53 PM
Turbojack's Avatar
Back in 2000 I was only wanting a single engine cat & to go over 100. There were a few 28 around then. Everyone said the same as GS, 85 & tearing up a lot of drives
Turbojack is offline
Old 08-18-2008 | 12:55 AM
I would think with a BMax it would last a little longer. The boat should weigh in the 6200-6400lbs (depending on interior and such). Mine has twins and its a little over the 7300 mark but I have a ton of stereo equipment, blowers, etc.
I would say everyone is pretty close. Boat might run 90mph. A buddy had a 99 28 Daytona with a 1000hp motor and it ran about 102mph.
As far as top speed for the hull. That all depends on the power. I have been 127mph so far with 3 people in the boat. The 99 TD's are much heavier then todays 28's, but ride better in my opinion.
Upper Hand is offline
Old 08-23-2008 | 12:35 AM
Default 26 ICC then?
So how would a 26 ICC handle some bigger waters? I don't mean offshore, but say Grand Lake in OK? Can you boat on most holiday weekends safely with this hull? My 25 eagle gets pretty unbearable on the big weekends out there! I know you couldn't go 100 but can you get 60 or so?
Will the 26 ICC handle larger waves better than the eagle? Do you think for a rough lake I should go ahead with the twin 28? Don't want to be having planing problems though, that would suck.
Old 09-04-2008 | 10:18 AM
Default Thanks
Ended up buying the 26 ICC, and it handles big water fairly well. Well, at least MUCH better than any small vee, and we were fine on grand on Labor day..just had to watch the rollers so we didn't air out 10 feet, lol.
Old 09-04-2008 | 08:32 PM
Turbojack's Avatar
Trim down when you get to the rollers. You will float right over them. Only ones you need to worry about is the big cruisers plowing & making the killer 5' rollers
JJONES
Eliminator
4
05-20-2006 10:00 PM
fastlane40
Eliminator
1
10-30-2005 12:40 PM
johnnyboatman
Eliminator
13
08-29-2005 10:42 PM
gdfatha
04-19-2003 09:28 PM
RiverGirl
04-26-2002 02:59 PM
