502 ho cam specs?
call ultradyne and talk to Tim golsbe he's the man they did all the cam engineering in the 80's for mercruiser big block and small block chevys
Ultradyne Bullet Racing Cams at (662)893-5670
I have a gen vi 502 and I'm running Ultradyne Bullet Racing Cam roller 228 in 236 ex @ 50 112 cl with .601 lift with a 1.7 rocker
Or you can call RMBuilder"/Bob Madara of Marine Kinetics in N.Y. and have him do a custom cam profile for YOUR application. He has done many cam profiles for guys on here over the years and his pricing is very competitive. 585-654-8583
The 502HO came with the 500hp cam which from what I can find ran:
Lift Intake .5
Lift Exhaust .614
Duration @.050 Intake 2 Degrees
Duration @.050 Exhaust 230 Degrees
in other words, a fairly hefty, if not simple cam. (read Crane 731 - 741).
I'm going to run a 741 in a 454 Gen VI so a 502 should be easily able to cope!
Good luck.
Lift Intake .5
Lift Exhaust .614
Good luck.
