Drive motor
Old 08-18-2008 | 04:57 PM
jrocket's Avatar
Default Drive motor
Bravo 1 trim drive runs but I have no movement, stuck in the up position. . which way to go which way to go
jrocket is offline
Old 08-18-2008 | 06:26 PM
It should be the down trim solenoid. I'm not sure of the colors of the wires they are dirrerent than the up side making it easy to find.
Maybe someone can help. It could also be the switch.
RBeyer is offline
Old 08-18-2008 | 10:19 PM
Blue Sky - Green Grass
800XCR is offline
Old 08-20-2008 | 04:34 AM
jrocket's Avatar
somewhere to go! Thanks guys!!!
jrocket is offline
Old 08-20-2008 | 10:33 AM
If the pump runs when you hit the down switch then it's not the solenoid. It could be your trim rams are frozen. It happened to my dads boat(Bravo1). Had to have the rams rebuilt. The kits are about $60 each. Just a thought.
Warlock28SXT is offline
Old 08-20-2008 | 11:11 AM
Did you have the hose's off???
redcorvetteman3 is offline
Old 09-04-2008 | 08:12 PM
try someone heavy jumping on the drive while you hit drive down button - happens all the time
lookinforboats is offline
Old 09-06-2008 | 02:32 PM
Griff is offline
Old 09-08-2008 | 03:25 PM
tomas_wallin's Avatar
That sounds a bit too violent...
Have someone kick the drive downwards when you hit the buttom! If the trim motor runs ofcourse! If the drive has been sitting in the far most up position for some time it sometimes gets stuck and needs some help to break loose.
tomas_wallin is offline
Old 09-08-2008 | 04:36 PM
CPPerformance's Avatar
Default solenoid
Sounds like the solenoid, thats where I would start. Look here.
CPPerformance is offline
