Choosing props for a 29" Baja Outlaw? >
Old 08-19-2008 | 09:09 AM
Default Choosing props for a 29" Baja Outlaw?
I need help choosing the right props for my 29’ Baja Outlaw. Boat is powered by stock twin 454 Mag MPI’s. Currently I am running 25P 3 blades. They are slightly abused with some minor dings in them. I am only pushing about 4100 RPM’s with these. I am looking for some feedback to what is the best fit for this setup. I am leaning toward 4 blade props but unsure of the pitch I should use. Any suggestions would be appreciated.
gbeach is offline
Old 08-19-2008 | 09:59 AM
I responded to your other post but you should be able to turn the 25s faster than that. I would find another pair to try before spending money on smaller props. Typically the 3 blades were good props for the older 29s lower x diminsion. 4 blades will give you some extra cruising speed but cost you a few mph at top end.
jmeng is offline
Old 08-19-2008 | 11:24 AM
Custom Interiors & More
My 2000 29ol would turn 4600 rpm with 7.4 MPI's and 25p Mirage Plus props. Are you sure you are not turning 5100 rpm's ? I traded my 25's for 24p Bravo 1's that droped the rpm to 4550 and lost about 1 mph on top end, but the 25's were to hard to get on plane on Lake Erie in 3-4 footers without blowing-out. When I tested 24" labbed props, they were the best all around prop for speed, and take-off.
XT
XT-Innovator is offline
29KILROY's Avatar
26 Pitch 4 Blades Labbed period.
29KILROY is offline
Old 08-19-2008 | 03:50 PM
JasonSmith's Avatar
That is what I ran with my 454 MPI Mags. With the 310 motors I would go with 24 or 22 4 blades, labbed.
JasonSmith is offline
Old 08-20-2008 | 06:17 AM
29KILROY's Avatar
Sorry totally missed the 310hp part, in that case what Jay said.
29KILROY is offline
Old 08-21-2008 | 11:38 PM
mroutlaw_'s Avatar
I have a set of 24P Bravo 1s. Still in the box.
P.M me if you're interested in them.
mroutlaw_ is offline
gbeach
10
08-20-2008 09:43 AM
hotboat11
Wanted
0
07-07-2008 02:07 PM
buggyride
Prop Talk
13
10-03-2007 09:53 AM
DURANGOKID59
06-01-2006 09:26 AM
raiseyourdrive
09-15-2004 08:23 AM
