rebuild and get more hp out of 500 hp carb motor >
Old 08-22-2008 | 05:00 PM
Default rebuild and get more hp out of 500 hp carb motor
Well here is the deal i have a 500 hp carbed motor i got fuked on and if i am gonna be pulling it apart i might as well get some more hp out of it.
So i guess what i am wondering is where to start and part #s best place to shop any info that will help out. Goal is 100 to 150 more hp. pocket around 6000 to 7000.
Also if any has any thing to add that i should consider that would be great. Thanks Jeramy
You can see pics of the motor at the link below
http://www.offshoreonly.com/forums/s...d.php?t=193608
ubet28 is offline
Old 08-22-2008 | 05:19 PM
Registered User
Aluminum heads and a custom-grind hydraulic roller cam will put you there. As long as you have the exhaust to support it.
PM RMBUILDER- he can hook you up on the parts and the proper heads. AFR 315 CNC's are probably a good bet on what he'll recommend.
Chris Sunkin is offline
Old 08-22-2008 | 06:02 PM
Hey Chris you are great guy! I wish i could buy a beer. You have been a great help with this ordeal. The exhaust i have is EMI brand new wll like 10 hrs will this be ok?
ubet28 is offline
Old 08-22-2008 | 06:36 PM
blue thunder's Avatar
How many inches approx from the head does the exhaust gas/water mix with your emis? That has a lot to do with how aggressive you can get with the cam.
BT
blue thunder is offline
Old 08-22-2008 | 09:25 PM
KAAMA's Avatar
yeah to what he says!
KAAMA is offline
Old 08-22-2008 | 10:43 PM
Registered User
The Eddie's are basically Gil copies. They should be dry right to the tips.
Can you confirm that?
As far as the help, glad to. That's the idea of this place- sharing what we've learned. I've been the recipient many times.
Old 08-23-2008 | 08:56 AM
BY U BOY's Avatar
Depends on the risers he got with the EMI's.
BY U BOY is offline
Old 08-23-2008 | 09:27 AM
Registered User
I've not seen that many, but all of them I recall had an outlet right at the tip. Now, on a Bravo boat, that might not be that far away. Does EM make a mixer-style tail?
Old 08-23-2008 | 10:11 AM
you can make a solid 575 using the parts that are there and at the same rpm...do not let anyone do the work that can not complete it from start to finish....this includes dyno'n the engine as well.
audacity is offline
Old 08-23-2008 | 10:45 AM
klaw's Avatar
Charter Member #139 /Moderator/Platinum Member
had a couple 500 hps done over 3 years ago dynod at 565 each have been turnkey troubly free and I run them hard Ateco in waukegan did them
Kept the Bullet and the condo and joined the cig 20 restoration club.
klaw is offline
