PQ Legend Hull
Anyone here ever checked to see if a 2000 PQ Legend has a hook in the hull? Like put a straight edge along the bottom of the boat (4 ft. level or whatever) from the transom forward to see if there's a space between the bottom of the boat and the straight edge?
I understand some boats/hulls have the hook built in, to help with getting up on plane and help reduce the tendancy to porpose.
Thanks in advance!!
Thanks in advance!!
Thanks for the reply Knot 4 me. There's one for sale in the SW classifieds that has a decent asking price. I seem to keep going back to the add again and again LOL
My 23 Nova has the hook which is why I think it likes so much trim in the out drive at speed. I also think the hook might be slowing me down, as it takes 500 hp (ZZ502/502) to go 70 mph on gps. My ZZ has recently been bored/stroked to a 557 and I've been looking for a little more "hull" to drop it in. 26 PQ on SW is affordable, and seems like a good deal. And I've heard the 26 PQ is pretty good in snotty water, for a 26. Just a little hesitant about that phark'n hook.
Thanks again!!
Thanks again!!
they both weight about the same,but the sunsation has a pad bottom,you get a little more speed but a slightly rougher ride.
I've never ridden in a 26 PQ but I've heard the ride is good for a 26. I have poked around in one and I like the overall quality, cockpit size/room, and the wind shield too (family friendly).
Seems like tabs would take care of any tendancy to porpose and of course get up on plane. Think it might be worth the time/$$ to grind the hook out and re-gel that portion of the bottom??
I know that ultimately, getting a boat without hook would make more sense. But funds are limited. And the 26 PQ has allot of desireable features, to me.
Thanks, I appreciate the input everyone.
I can tell you this. The Powerquest pretty much needed the tabs to get up on plane. The Sunny doesn't bat an eye...tabs or no tabs. I believe the Sunny has a bit better ride but it is longer. I really liked the Powerquest...but was facing the same issue you are investigating. Pretty much was told by those in the know here you would have to throw a ton of power at it to see 80 and then the ride would not be so stable. I came across what i considered an H of a trade so I traded. I am happy and the most important part is my wife is tickled pink! Thought about blueprinting the hull but just couldn't justify it and would definately be a bit of a gamble.
the boat was designed to run without any tab at all,that is the reason the rocker is put between the outer lifting strake and chine,it has no effect when going fast,that part is out of the water.
sunation builts a good boat but think about what your are saying,you take a boat like the 260 with a deep V and will be a bit slower because theres more boat in the water,more drag,but when you jump out of the water and re enter it will have a softer entry/better ride.
now if you take the sunsation with the pad on the bottom and a narrow beam it will be a little faster because it rideing on top of the water with less drag but every time you re enter the water its going to have a hard entry.
again I am not taking anything away from sunsation,this applys to any pad bottom boat
