Trim Pumps
Old 08-28-2008 | 09:58 AM
scottsumrall's Avatar
Default Trim Pumps
How othen does the trim pump oil need to be changed and what is the best way to do this? Thanks
scottsumrall is offline
Old 08-28-2008 | 12:58 PM
I am not sure I would bother unless your boat is 10 years old. I have never actually seen dirty trim oil. Lets say it does 2 strokes per hour? Multiply that by your boat hours...pretty low wear item...atleast for fresh water.
The way I change mine is in 4 footers...the cap comes off automatically and you get to clean your bilge too
JRider is offline
Old 08-28-2008 | 09:13 PM
sunchaser796's Avatar
Unless you have water in the oil , I would'nt worry about it !
sunchaser796 is offline
Old 08-28-2008 | 09:27 PM
ZXXX Donzi's Avatar
I used to change the oil in my tabs every 10 hours until I switched to synthetic. I now do it every 15 hours. I installed a cooler and that seems to help too. Or was that the drive?
ZXXX Donzi is offline
Old 09-02-2008 | 11:55 PM
Never changed it unless I had a problem with a pump.
Griff is offline
Old 09-02-2008 | 11:57 PM
Also if you want the tabs or drives to move faster, you can run a thinner oil. If one moves a little faster than the other, you can cheat by running thinner oil in the slow pump.
Griff is offline
CAPTAIN CHUCK
Drives and Lower Units
1
06-04-2007 09:53 AM
toggle throttle
2
05-07-2007 08:38 PM
wstultz
2
01-23-2006 10:09 AM
cigarette39
5
11-26-2004 09:04 AM
Biggus
06-23-2003 08:23 AM
