coupler bad? >
coupler bad?
coupler bad?
Old 08-31-2008 | 06:47 AM
offshoredrillin's Avatar
Default coupler bad?
Whats it like when a coupler goes bad? I see lots of grease behind the motor and it seems to rev a little higher like it is slipping, is that indicative of it going out?
offshoredrillin is offline
Old 08-31-2008 | 06:59 AM
Panther's Avatar
Frank's Marine Service
sounds like it might be going bad to me. What syle couplers do you have, the HD or standard units?? Are you sure it's grease or rubber?
Panther is offline
Old 08-31-2008 | 07:07 AM
whichever comes on the 500 efi, I'm pretty sure it is grease or oil, I'm going back down to check today, it was dusk and I noticed it when I docked, with my trailer down, I havent been able to clean the bilge properly but it seemed like it was excessive, I'm going to try to clean it today to see if I can tell where it is coming from.
Old 08-31-2008 | 07:55 PM
blue thunder's Avatar
Everyone I dusted ripped out the splines and was like the boat was in nuetral. There was no "starting to go about it". If the rubber let get like Panther said, you will have bits of rubber all around under the hatch and you would have smelled burning rubber.
blue thunder is offline
Old 08-31-2008 | 10:23 PM
As Blue Thunder said.
Theres no starting to go.
whoya is offline
Old 08-31-2008 | 10:31 PM
If the spline goes it is all at once. The rubber may slip and if you recognize it slipping with in a few seconds and idle it may cool, set up, and allow you to idle home. If you stay in it when it slips it will go away completely. Once it slips once it needs replacement.
MOBILEMERCMAN is offline
Old 09-01-2008 | 01:11 AM
thanks for the tips guys, good news is coupler was fine, had a couple valve cover bolts back out and replaced them today, all tight and dry again
Wobble
34
05-04-2005 03:08 PM
Waterfoul
04-21-2005 07:47 PM
LostinBoston
11-27-2004 08:56 AM
Keith
04-30-2002 10:15 PM
Shanghied Again
03-11-2002 08:42 PM
